Legacy Maya render layers and sky only render
Are there any known issues with using Maya’s legacy render layers to output only a beauty pass of the Vray sky with clouds?
When I set this up I can get a render into the VFB as normal, but the saved file comes into both Photoshop and After Effects completely transparent. This is also true with a batch rendered layer.
Nuke seems to be able to read the data, but I don’t want to work in Nuke.
just output it without alpha? its most likely baking in the alpha with thr rgb, and in photoshop its bringing it in as transparency. AE probably has a better way, I don’t really remember how to use it it’s been many years.
Good suggestion – although in the end I already just worked around and output as a TIF sequence which seemed to clear the problem. AE is just horrible for working with multi EXRs but I can never bring myself to switch entirely to Nuke as overall I find AE more user friendly for a lot of things and am so much more proficient in it.
It says you haven’t posted in 12 years. What?
my old account is in limbo not sure what this one is haha.
