Hi! I need help! I archive scene and send it to another computer, but when I open it on another computer and try to start rendering, corona gives error notification and doesn’t render: LEGION_STOP @ C:\Corona\src\CoronaCore\misc\shaders\SkyShader.cpp(294).
I delete Sky and Sun and place them again. Once this is done Corona start rendering, but Materials look like they have stains or like some filter is used for this picture. And some materials don’t displayed on CMasking_ID element.
I try to archive scene different ways, with resource collector in 3ds max and using script collect asset. All the same.
What to do?
Obvious question - does Corona versions match between two computers?
Yes, versions are the same.
This looks to me like the scene was saved in Corona V6 with the new sky map and you are trying to render it in V5 which doesn’t have this feature.
Unfortunately this is an unsupported scenario, scenes saved in newer versions of Corona are not guaranteed to work in older versions.
I think the easiest fix will be to update the installed version of Corona to V6 HF1.
Let me know if this helps.
Rowan
Yes, you were right. I was sure, that versions are the same, but they are not.
Updating helped. Thanks!
