Made by enscape2.8 & Rhino6
@Atelier_P.D , how did you create this 360 degree video using Enscape, or rather making use of Enscape?
Also, a small thing but, I can see some flickering here and there around the doors mostly - this is something called z-fighting which occurs when two surfaces are interlapping into each other. Enscape (or usually any other 3D software) cannot know which surface to display (since they’re both located in exactly same place, occupying the same space), so it begins to flicker. Simply make sure that none of those are interlapping and that should resolve it. ![]()
