Hello.
As part of a personal effort to combat what I perceived as workflow degradation or limitation over the years, I coded two plugins to put right some of my personal sore points.
EDIT: Builds have been updated with additions (VFB) and minor corrections (both). Installing the new ones will reset the license timers.
LeleTweaks_MAX:
This attempts shortcut reparation across the Max UI, and one click render cancelling, both features lost when Max transitioned to Qt UIs: the redraws got an order of magnitude quicker, but the user pays with extra clicks..
So, with the plugin active, you will be able to press F10, edit a V-Ray setting, and while the cursor is still in the edit box, press f9 to quickrender.
Or toggle a light on, and immediately press f9 to quickrender.
This of course works with the shortcuts the user set for their 3ds Max.
As for the one click to reach the cancel/stop buttons, it’s self-explanatory.
The plugin has one simple toolbar and icon that toggles it globally on or off (or you can do so via maxscript, of course, if you don’t want the added toolbar.), so the behavioural differences will be evident, and safe (off is really, really, really off.).
LeleTweaks_VFB:
This applies the same approach to the VFB.
As the VFB is markedly not a black box, I could edit it and augment it as i saw fit using the SDK alone.
Modifications to VFB behaviours:
Copy Ops with highlight: now it’ll be clear what you’re copying, and when. Also enables easy copy from the log text (i.e. select and ctrl+c)
Edit boxes protection: now selections stick even if the mouse leaves the edit box. also most of the realtime focusing churn from them is gone.
Shortcut passing + Focus protection at render’s end:
These two live together: the former passes any shortcut (also called “accelerator” in Max lingo) the VFB doesn’t own back to Max.
The latter stops the VFB from passing focus at render end back to Max.
With them both active, for example, you can render → the VFB stays focused and in the foreground → press F10 with the VFB in focus → Max’s Render settings show up. -
Update Button: I keep hitting it on a big monitor with high resolution, which in turns pops a browser window in my face. So, three customisable options are given: default/move/hide.
Additions to the VFB:
Color Picker.
Variable Kernel Size to 15x15 px (shift+mouse wheel)
curr./min/max/avg displayed at all times
Stick/Compare two picked kernels across any two AoV. (click to stick, shift+click to move the picker to the stuck position, with debouncer to have the cursor stand still.)
Ctrl+click to Color Copy as float, conversion for pasting directly into max color swatches (currently only adds a 2.2 gamma, so no OCIO is supported, yet.).
Alt+click/MMC panning while picking.
Exposure Caddy
- Always temporary (alt+e) or possibly permanent (ctrl+e) exposure settings without chasing the UI, reusing the VFB display-only exposure control.
Ctrl+Alt+e resets exposure to 0.0, without need for mouse interaction.
Options:
- Added an own entry under the VFB Options menu, which allows the toggling of (groups of) features on and off, and adds user options where it makes sense (Colors, transparency, scale, fonts, etc.)
Work is ongoing, more features/options can and will be added, and of course i’ll be listening to requests.
For the moment, these run with a 1 week license (counted from first start), in max 2026 and 2027 only, so to allow me to share them with you without the trouble of adding a proper licensing system, and as a way to get feedback, and gauge interest.
It’s the AI age (and sure enough these came with help from one), so who knows if there are still users counting their needless clicks…
You can however PM me and I’ll provide for either a new build which resets/extends the timer, or a time-unlocked one.
What am I looking for?
Chiefly, misbehaviours: some text box in some obscure plugin may not behave with the plugin active, the color picker may get stuck if a set of ops are performed while it’s active, and so on.
I have done all the QA i could by myself, but nothing beats User testing.
Are these Official from Chaos?
Absolutely not.
There is going to be no support from Chaos of any kind, and they are not going to be integrated at a later time: this is a personal effort.
However, I do have permission to post and share them as I see fit.
