Hi guys. I need to make a lens which distorts an image in an animation. Here is a sketch of the image distortion required on the left side (it will be a more smooth distortion - ignore the hard lines):
So I guess my question is, what is the best way to accomplish this using the Vray Camera. Since it will be animated, is there a better way to do this in post with Photoshop Batching or After Effects? Should I ‘create’ a glass lens in front/attached to the camera? The last option would require a bit of guess work I suppose.
It’s totaly a guess work. Try asking Valdo about this, as I saw his small workaround for this I mean - you tell which distorsions formulas should be used by VRay Ph.Camera…
He recently commented on matchmoving with Syntheyes if that’s what you are referring to - but this is a different case. It’s like lens correction with a really funky shape.
By looking at those pictures, I’d guess the bulge would mean a greater bubble (depth) at the bottom? Just having problems trying to picture what a lens would do to achieve that.
There’s gotta be a much easier way to accomplish this…
