Hey guys, where is the Lens Effect setting gone from the frame buffer?
Nowhere to be found.
Let me know, thanks!
Hi @vanja_uri ,
You should be able to find the Lens Effects layer under Display Correction in the VFB, see attached screenshot. You will need to enable it, as indicated in the screenshot itself. Hope that helps.
Ah sorry, the display correction was completely hidden. My bad!
