is it possible to render out the lens effect with the C4D Render output?
Honestly, I thought this is possible, thought I did it in the past, but maybe I am mixing it up.
Using the latest build with latest R26 on windows.
Thanks!
Thanks!
Hello @haniel1107 ,
Do you by any chance have the Sharpen/ Blur filter calculated in the VFB?
Hello @aleksandar.kasabov ,
I have just the exposure on. The lens effect deactivate itself when I start rendering.
Hey, haniel,
Thank you for the question. The V-Ray lens effect is post-effect and is applied when the render is finished, so you have to use the V-Ray file output. Maybe, you can save the VFB as LUT and lens effect as render element only, but it is a tedious workflow.
Cheers,
Hello @haniel1107 ,
Upon testing on my end I was not able to reproduce the issue and the lens effects are saved when using the native C4D output system. Do you have the “Apply VFB Composting and Color Corrections” option enabled in the Common tab of the V-Ray settings? If not, please make sure to enable it and let me know if that helps.
If you still experience the issue after that, please share a simple test scene where the issue is reproducible so I can have a look. Thank you.
Hello @boyan ,
ok thanks. I thought it was working, but then I mixed it up.
Thanks!
Hi @aleksandar.kasabov I thought, too that it will work, as I think I used once. I will test again, You say it should work, Boylan not.
I have the option you mentioned always activated, also this time.
Hi again @aleksandar.kasabov ,
I tried again with a simple scene. It doesn’t work with the C4D output.
Lens effect switches off during rendering and switches on again after rendering. But it doesn’t save the effect.
Please find attached a test file and the result.
Lens Effect.c4d (261 KB)
Hello @haniel1107 ,
For this to work, please make sure that “Save Glare channel” option in the Lens Effects options is enabled. Please check this screenshot.
Let me know if that helps.
hello @aleksandar.kasabov , yes great. This helps a lot! It works fine with your example.
Thanks a lot!
I also noticed that … why is that ? to show the user that is is applied after the rendering ?
it is very confusing that an user chosen option is by itself toggling on and off.
its like the switch at the same time is an activity status display. (?)
