olly
September 27, 2020, 1:11pm
1
Is it possible to apply lens effects to cube 6x1 VRIMGs loaded into the VFB?
You can definitely apply them to a “standard” camera renders, but I am having zero joy with my vr renders…
I am running max 2021 with vray next 3.2.
Anyone got any ideas/experience they can share?
Cheers,
Olly
Please refer to this post about the matter.
olly
September 28, 2020, 1:32pm
3
Thank you for replying, but this is a separate issue to the linked post.
I want to be able to load a pre-rendered VRIMG from disk and apply the lens effect as a post effect.
This works when loading a standard camera render, but not when loading a VRIMG rendered as cube 6x1.
FWIW, the VRIMGs are rendered in stereo so 18432 x 1536 pixels…
Hope you can help?
Neilg
September 28, 2020, 1:54pm
4
it’s probably a memory issue with an image that size, nothing about it being 6x1 would prevent that from working. the vfb and lens effects is just looking for pixels with a value above 1.
You’ve not baked in color mapping have you?
olly
September 28, 2020, 2:10pm
5
No it is straight up linear and the pixel values report as expected - over 1 on light sources etc.
When you say memory, are we talking ram or vram for this?
