I’ve noticed that lens effects aren’t rendered using BackBurner rendering, as long as hardware acceleration is activated. Our rendernodes are blades without “real” graphic card, so I guess it’s the reason. The only way to get lens effects rendered is to uncheck Hardware acceleration. Could there be some kind of checking to prevent this ? I mean, I want to have Hardware acceleration activated on my workstation, when I set up rendering, but I can’t be 100% sure we’ll think about desactivating this option every time we send BB rendering …
Can anyone reproduce this, please ?
It’s at the root of C:\ ,right ? it’s weird, the file shows the last time it was modified was on February … whereas we use our rendernodes nearly everyday !
It should be in the windows temp folder > "%USERPROFILE%\AppData\Local\
You can get instant access to this folder by typing %temp% in the explorer address bar.
That’s great that you don’t get any slow down, but It would be good to see the log file. Maybe there will be some useful info.
Please find enclosed the VRaylog.txt file. From what I see, it seems it was reset yesterday … so I doubt it will provide useful infos vraylog.txt (765 Bytes)
Me again … I’ve ran another test, submitting the job with BB to one master machine, spawning 3 others. “Restart Servers on render end” was off, Lens Effects activated, with hardware acceleration ON … I can confirm Lens Effects haven’t been rendered. Please find enclosed the vraylog file.
Thanks a lot for your help. vraylog.txt (765 Bytes)
Unfortunately this log is still empty. Please tell me how do you save the render. Do you use the VFB - Save separate channels or the 3DS Max - Save file.. ?
Maybe we can try to localize this issue in remote session if possible?
This one
Sure, up to you for a remote session (but I don’t have any microphone at work) or anything else that could help solving the problem.
Just to detail a bit the method we use:
- set up an output file name in the 3dsmax Render Output section (Common tab)
- activate DR for machines let’s say 2 - 3 - 4
- submitt job to BackBurner, to only one rendernode (machine 1), that acts as master, spawning machines 2 - 3 - 4
Does it seem weird to you ?
This workflow seems to be working fine here. Our renderfarm don’t have graphic cards installed either.
Can you remotely log in to “machine 1” and try to render the scene locally ? Then watch the Log for any errors.
Remote session is still an option, just send an email to support@chaosgroup.com mentioning this forum thread so we can arrange a convenient time for both sides.
Hi Tashko,
I’m afraid I can’t do that, because I’ve no access to 3dsmax UI on the nodes, 3dsmax is licensed for rendering only apparently.
I’ll send you an email for remote access session if possible.
