The intensity slider only goes to 10. though the actual intensity is maximum 100.
I only just noticed this and it was driving me crazy that I could not get the effect I was expecting, leading me to pumping the light outputs up, which of course affects everything else.
The slider is locked to 10 but the spinners go to 100.
So naturally it’s not major thing if you do know that - but I absolutely view it as an UI error which tripped
me up mid-project and was a time-waster until I realised.
I overlooked the spinners, as the slider is most prominent,
which induced me to believe that that was the limit, as it is for the other slider on the tab.
Hehe, yeah I do now. I am at the end of getting out 26 incrementally different views of 2 products that needed some degree of colour
consistency between very different shots, needing varying lighting between them.
Not having (as I first thought) the ability to go above 10 was driving me nuts and seriously wasted probably a full day’s time of messing around.
I should be more annoyed but the VFB is still a bit WIP so I can only blame myself
What is odd is that you are the only one to comment on it…thanks for that in any case
Ah ok, so there have been user complaints which resulted in this decision. Sorry, I didn’t find anything so I guess leave it as it is if the majority of people are
content with it.
I just thought it was confusing and certainly tricked me into thinking it was a cap, based on the spinner/slider above it (although that one is capped actually at 100).
