In latest nightli lens effects still break IPR rendering. What I mean, when lens effects are enabled, IPR start rendering and after few passes lens effects are computed, but after that IPR continue to compute better image but never show it. Image is on 100 pass but I still see 4 pass image in frame buffer and have to click on update lens effects button to update the effects AND whole image to see latest pass. Its really annoying.
I experience the same problem. And yes, it’s annoying to always have to click the Update button. Hopefully a fix is possible before official release.
Yes, will fix it.
What about this issue?
VFB change element to effects with lens effects, but cant see continuous rendering from normal render element. Is there a way how fix this?
You can switch to the RGB element at any time by clicking on the “RGB” button in the VFB. Alternatively, in the V-Ray System settings, there is now an option how often to update the effectsResult element.
