Lens Effects
Since when do Lens Effects denoise? When I enable the Lens Effects, my image becomes butterly smooth, not in a good way.
Lens Effects on
Lens Effects Off.
Do you have a denoiser on as well? If so, is its multiplier less than 1? I’ve had issues in the past where enabling the lens effects forced the denoiser to full multiplier regardless of its actual value. I thought this was fixed though as I haven’t had this problem for a while.
I do, but only at .2. When Lens Effects hits, it is like having the Desoiser at 100%—the denoiser can be on or off; it doesn’t matter, but I have a Denoiser in the stack. I am using the NVIDIA solution, so I’ll try changing that.
Yeah., that’s the problem I encountered as well. I THINK I may have worked around it by checking/unchecking some options on the lens effect settings: interactive, create lens effect channel, or something (I can’t really remember). I’m using Intel denoiser btw.
Yes I have this issue as well. I think it’s a bug. Lens effects seem to force the opacity of the denoiser to 1.0.
I managed to reproduce the issue. It seems Lens Effects’ “create effectsResult channel” overrides the Denoiser layer’s opacity. Logged as internal tracker id: VFB-158.
Well that explains why I never use Denoiser, I always get the shitty result and create effectsResults channel is always on. I just though the denoiser was horribly bad but turns out it’s a bug :facepalm:.
I don’t think there’s a point to checking the “Create effectsResult channel” if you have the denoiser enabled anyways. Once the denoiser is enabled, an effectsResult channel is automatically generated and is always at 100% (as far as I can tell), only the RGB Color channel reflects the Denoiser opacity. Once “Enable Lens Effect” is checked, the lens effect is added onto the effectsResult channel, regardless of whether the “Create effectsResult channel” option is checked or not. All that seems to be affected by it is the influence on the RGB Color channel (which is where the error shows up). Maybe this would affect something if it’s saved to a multichannel exr?
This proves that it’s way more complicated than it needs to be…
Curious to what’s the reason for turning on “create effectsResult channel” (off by default), or is it something you’ve forgotten about? As @dlparisi mentioned, having a Denoiser will create it automatically.
I haven’t done much with this workflow, but chiming in from a thought experiment perspective - Wouldn’t it still be valid to enable the effectsResult channel if you were doing lensEffects other than denoiser, and wanted to be able to separate out the ‘raw’ / unaffected RGB in the RGB channel from the lensEffects channel? Not using Denoiser, but enabling Bloom/Glare, want original rgb without bloom as well as option with it?
That’s what the option is for. The issue is when it is used in conjunction with the denoiser’s automatic creation of the same element.
