hi,
had this scene setup on vray 3.4 and was rendering fine, after upgrade to vray next, I´m having extreme color dots on the renders that create wrong flares.
what would be causing this?
There is another user who posted the same problem. Vlado said that he is working on a fix.
thanks bobby, could you point me out the thread you talk?
Sure, here you go.
thank you!
Email me to vlado@chaosgroup.com with your 3ds Max version and I will get you a build that might help - if not, I will need the scene to figure out what’s going on.
vlado, the version you sent me, fixed the issue! thank you.
Is this going to be implemented on vray cloud?
Thanks for the confirmation, Leonardo! Yes, we will implement this in the V-Ray cloud. I’m not sure when exactly, but I will let you know.
vlado, so, if I´m going to use vraycloud at this moment, I better stay on latest official release, right?
it´s happening on almost all Interior scenes I´m working right now. Anyone can take a look?
It doesn’t look like an error to me in the last images you posted. It is the reflection of the light source in the metal parts of the chair. I bet if you pick the pixel values, they are way above a value of 1. Which would be correct, as it is the light fixture at the ceiling being reflected. The glare at the rail on the balcony seems to be the sun being reflected.
those you mention are the correct behavior. but, take a look at the upper left corner and you will see what I´m talking about.
