Levels in VRay 5 Frame Buffer?
Is there a Levels modifier in the VRay 5 Frame Buffer?
You can use the Curves color correction for a similar result - it shows you the histograms and everything. We debated whether a separate Levels color correction was necessary and in the end decided to try and see if we can combine it with Curve one instead of having two different corrections that do a very similar thing.
