Any one else having issue with the 3.4 asset library not letting you select a specific section?
Adding to this, the search function doesn’t seem to work, for instance searching for ‘people’, but it works for ‘chair’
Hi, I have the same problem… (version 3.4.0+84039)
Absolutely. Enscape 3.4.0+84039 with Sketchup Pro 2022. The asset manager is completely useless. Crashes. Can’t select categories. It renders the entire program useless if I can’t put in my entourage as I normally would. I will have to revert until this is fixed. MAJOR PROBLEM.
@Demian_Gutberlet is there a fix coming for this, assume it’s a known issue?
Did you have the ‘offline’ selected in the asset library in 3.3?
3.4 has completely changed the way the asset library is structured.
I had offline selected and the lib was screwy, once I unselected the offline option and then re-selected it (telling it to re-download everything) all was well.
My asset lib in 3.4 is working perfectly.
You’re awesome. That seems to have done it. After unclicking the offline assets, it worked fine. I’m going to be re-downloading soon, but I have every expectation that it will work. Thanks.
@Paul_Russam legend, fixed it straight away ![]()
Glad it’s working for you.
Next time you experience something off it might be a good idea to not assume it’s a ‘major problem’ / ‘known issue’ and do a little testing yourselves.
Why we have the community
