topic say it all
i wonder about low server performance and notice LS currently eat 1,5gb ram refering the task manager
do the LS store the log files into memory ?
around once per month the “LS not found” error appears - i guess the server runns out of RAM and die/hangs
I read somewere about that problem, and I check my lic. server, it consumes 3k only after 3 days of hard rendering - dr involve 4 pc-s, LS is in main machine that I work on..
Before that it was on machine that I dont use for rendering, and haved some issue, slower performance , deleyed starts, hangs, mat editor slow openings. After I moved LS on main machine and the problems gone…
hope that help…
if not, reinstall Vray on all machines..
You can try to update the license server machine with the latest dongle drivers from the WIBU site (http://wibu-key.com/download\_user.php - scroll down to the WibuKey section), and also with the license server from the latest V-Ray version. Also, there is a program called Network server from the WIBU drivers, make sure it is not running.
