License at work / home
We consider bying a license for Sketchup.
Is it possible to share the license ?
If I use it at work, can I then unload the license and use it at home ?
Jorgensen
Re: License at work / home
Anyone ?
One more question. Is there included a manual that in depth explains the setting in Vray (they are quite comprehensive)
We are in the process of developing a network liscensing system which would allow you to use it at work or home (as long as it isn’t being used at the same time). As far as a manual we will actually be releasing one hopefully today that will lead you through vray for sketchup. This will be available for download and, if we get enough requests for it, hardcopy as well. If you also want a setting by setting rundown of what each one does, the Spot3d is the way to go. Its for max, but vray is vray.
We give 1 license out with your purchase - but if you contact us and request one for your laptop/home PC we will generally give you the extra activation. Contact support@asgvis.com with your serial number and an explanation and I’m sure we can take care of you
