I run the Vray license on a server, which I tested and it works. The computer normally used for rendering is networked to this server and I can browse the server from this machine, so my network connection is working, but it won’t see the Vray license.
It used to work untill about a week ago, but now I have no luck.
I do have a firewall installed, but VRay was working even with it installed. I will check if a setting has been changed, but since I have access to the server with the firewall settings as they are at present, should VRay not have access to the license file as well?
As far as I know they have changed the licence server for the next build so that it will be more compatible with FW and AV software. I don’t know when this will be released though.
