License Server - Manual Start!
Hello, All -
I apreciate that this topic has been raised recently, but I’m still no closer to a solution…
I’ve just installed SP3. However, when I select Vray as my renderer, I receive the “Could not obtain a license (10061)” error message.
I’ve found that if I start the “Launch Vray License Server” maunally, by double clicking on the icon, Vray works as normal!
How do I rectify this problem? Someone mentioned that I may need to “update the License Server” - but how do I do that?
Any help would be most apreciated!
:0)
Perchpole
You need to have the V-Ray license server running whenever you wish to use V-Ray. You can make the license server to start automatically by registering it as a Windows service. To do this, go to the Start menu > Programs > Chaos Group > V-Ray for 3ds Max > Licensing > Administration > Register V-Ray license service. This will cause the license server to run automatically each time Windows starts.
Doh. I knew it would be somat simple.
Thanks, Vlado.
:0)
Perch
Upon re-instaling SP2 - even though I did register it - it does not start automatically !
any solution other than dragging it to the startup folder ?
Nir
Can you see the service in the Windows services list? Is the service type set to “Automatic” rather than “Manual”?
