Licensing and Rush
Is it possible to use your distributed rendering licenses to render over rush? Or do you need standalone licenses to be able to do this?
Right now im receiving this error on rush submit:
Error: Could not obtain a license (61).
Error: Scene modified. Use file -s to save or quit -f to quit without saving.
Im at a loss. I have distributed rendering working correctly, but I cannot get these license request errors to go away in rush. Are you rush users out there buying standalone licenses for all your render nodes?
It should work, i think. We use Renderpal and that works. Try to access your licensing web interface and have a look at the available licenses. Dunno exactly how right now, but it should be stated in the licensing and install docs.
Can you render locally on one of your slaves? Is it able to get a license then?
You might want to check the firewall on your slaves.
Is this on Mac OS X? If yes, then the error means that V-Ray could not connect to the license server - probably the IP address of the server is not configured properly (using the setvrlservice.exe tool).
Best regards
Looks like its working now. Thanks guys.
What was the solution?
