Will the light cache calculation ever be distributed across all DR nodes? I am sure I read somewhere (several releases ago) that it now was, but I see on the help page it cannot be distributed.
Just from an environmental point of view; if the calculation cannot be distributed, do all the nodes really need to calculate their own version? Surely the host could send the completed solution to the nodes and save a ton of energy?
Just a thought, but please let me know if I am missing something obvious here.
I use a GI pass and a beauty pass for each of my animated sequences. The GI passes use DR on a single frame & “use camera path” enabled to calculate the LC & IR maps. The beauty pass calls these saved maps. Would it work to split the LC & IR calcs into separate passes where the IR Pass calls the calculated LC from file?
It’s been back and forth a number of times; in the latest 3.6 release it’s not distributed. We need to add transport of the data for the full light select elements. It will be fixed for the next patch.
