Light cache render via distributed rendering
Is it okay to render the flythrough light cache pass on my machine with DR turned on?
I think last time I check my IR+LC rendered fine with DBR… not sure tho was simple scene.
Thanks man. I was pretty sure you could as I’ve done it before but being very tired makes you a little unsure sometimes.
For most of the cases are better to calculate LC on the workstation and load it for the final render, in order to prevent all machines to make the same calculations and join to the rendering phase. Especially when some of the render nodes are slower.
