light cache world scale
Im having trouble understanding how this works and how you determine the world scale size? This tutorial Chaos: Industry-leading design and visualization software says set it to 15cm
Where as this tutorial Chaos: Industry-leading design and visualization software says set it to 2 with the added information:
“This can be done, for example, by creating a geosphere directly in the camera viewport or a Tape object and using it to visualize the sample size.”
what exactly does placing a geosphere in your scene achieve? and what size is a good size as a starting point? 2cm or 15cm?
It all depends from ur scene… Big scale scenes (KM) u might set it to bit higher settings. If it comes to small scenes, loads of detail u might want to have it very low…
Either way ur scenes have to be scale accurate or if they now u just have to guess, or use geosphere u described to find out suitable size…
