Hi, I’m fairly new to Vray (and totally new to this forum). I’m using Max 7.0. I import my geometry with DWG Link as I model in Microstation.
http://richardwoolsgrove.com/cad/pagePhotoLarge.php?photo\_id=68&cat\_id=17&pageNum=1
I’d just like some comments/advise on these images. I have an HDRI environment - just for looks, not accuracy of an existing interior - (there are only 3 walls forming the corner), the light is from a vray light material and I’ve added a series of omnis in the fitting with very low res shadow maps to get the blurred lighting shadows on the wall.
I think I need to up the brightness of the light itself and was thinking of adding light(s) as fill. I have some different options to do with the rings as solid (they are semi transparent right now)
The image size is 2250 x 3000, the small fitting took 1h20 and the large 3h45.
As a beginner- any comments/crits would be welcome. - The design is not mine.
Many thanks,
Richard
[/url]
