Hello. I got a weird problem. All Vray lights that I create are of tiny scale and look like a dot no matter how close I zoom in or how much I scale them up. All other Vray objects seem to be of normal size and react to scaling as expected.
I am wondering what’s up with that, please help help help. My maya is 2016 (by the way, Maya 2015 and Vray work just fine). Vray version - vray_edu_31001_maya2016_x64
Update: I tested different viewport renderers and found that only Viewport 2.0 has a problem.
Make sure you’re using openGL for the viewport. All the vray locators and manipulators use openGL in Maya and you won’t see them in DirectX mode (Maya preferences > Display)
You also might want to check if there is an active viewport filter (show > locators, manipulators).
Switching to OpenGL helped. Thank you yolov.
