I saw this quote by jujubee:
a drop down such as the one that ships with Max IES or ‘other’ software packages to help simplify what is essentially ‘guessing’? This process is overly-complicated…
i.e.:
25 watt flourescent tube
75 watt cool white light bulb
450 watt high-pressured sodium lamp
etc…
and I think that this would be a good feature to add to Vray lights. Even better would be the ability to input the wattage of the light as the intensity of the light. Eg. you want a 65 watt bulb in your scene. You create a Vray light, you type 65 watts into an intensity input box in the Vray light rollout and consequently you get a 65 watt output bulb in your scene. Then in a selection menu below this there could be the type of light like flourescent, incandescent, etc.
