There’s something strange happening with lights and refractive objects. If a light passes through a refractive object with glossy refractions even slightly lower than 1.00, the light’s intensity severely drops. Even if I set refraction glossiness to 0.999 it makes a huge difference in how Vray renders the lights. It’s as if 99% of the light’s energy is suddenly lost or cut off for some reason. Please check the screenshot below. The 2 images should be pretty much identical and look like the one on the left, but the one with refraction glossiness of 0.999 is drastically different visually. I am attempting to do a milky glass effect for the glass pieces in front of the cylinders like here, but as soon as I decrease the refraction glossiness, the lights dim significantly and I can’t achieve that effect. ![]()
Hi are you using visible lights behind the glass? Why not just increase the light’s intensity?
Yes, the lights are visible and their intensity is 1000000 in “Default (image)” units. Please see the attached scene.
light.7z (352 KB)
It works fine for me.
What behaviour would you expect?
Hi Lele,
I would expect the light not to dim at all with refraction glossiness of the glass set to 0.999. Did you test with the attached scene from my previous post?
I have, it doesn’t misbehave at all between 1.0 and 0.999, that’s why i am asking.
That’s strange. Please see attached a video I recorded. I’m using Max 2023.1 and Vray 6.00.04 build 00000 (the version before hotfix 1).
2022-08-03 13-40-13.7z (1.63 MB)
Mh, i see what you mean now.
Isnt it because of the max ray intensity? Bump that up from default 20 to 200 and youll see a difference and possibly lots of fireflies…
Indeed, that’s what it is.
I was wondering why i had never seen this behaviour before, and it’s because i have MRI always off. ![]()
Increasing MRI to 100 and above gives me a ton of fireflies that are very hard to resolve so that’s not a solution for me. I still think there’s a bug somewhere and that this should not happen even with MRI at 20 because there’s just 0.1% difference between glossiness of 0.999 and 1.00. So why does the light dim hundreds of times?
It’s due to the way a ray is considered when behind rough glass.
No bug, i’m afraid.
Fireflies, where you want to light with exclusively caustic paths (i.e. light through glass), are par for the course: you’ll need to sample much more for them to converge, if at all.
