I’m working on an interior and I have light leaks in a corridor that shuold be dark beacause there are no windows and all lights are turned off. I had the same issue with another corridor in a previous work but I solved it by adding an 30cm thick extra ceiling to all the appartment model. I guess it could be a lightmap issue but I can’t figure out how to get rid of it. Generally I subdivide the walls and ceiling surfaces into smaller ones and I make them thick enough but this time I can’t solve the problem. The strange thing is that this leaks appeared at some point, I made several wip shots and the light behavior in the corridor was correct. Do you have any suggestions?
