Light Linking does kill self shadow
Is there any reason why light linking does kill the self shadow.
If you use Illuminate by default off like shown in the video.
lightlink.zip (1.29 MB)
Second issue if i create a new object it gets illuminated. Which should not happen if im in “NOT” illuminate by default mode.
I cannot reproduce this on a similar scene - could you attach yours here? From what I see you’re using a VRayLight, which does not have the “illuminate by default” option. What do you mean by your second question?
Here is a new video and the scene.
lightlink.zip (26.2 KB)
And here a video with the “adding new assets to the scene” issue.
Just check how Arnold is doing it.
Thanks for the report. I’ve logged both issues (internal bug-tracker id: VMAYA-11250) for developer investigation. For now, manually linking/delinking may be used as a workaround.
Thanks!
Its a lot of work todo it manually if there are hundreds of objects in the scene.
