Light material problem
please does anybody know where you could be problem in this situation? I have one object (chandellier) where when I put light material it renders as black. The same material was used on a new cylinder and it works with no problem. (on pic you can see the difference between normal cylinder and 2 cylinders from chandellier)
Thanks for any help
Problem solved … All the light objects have flipped faces.
