Light Mix Render
Is there a way to stop the light mix from rendering in the batch render? Every time I render something, it creates the file I need but also renders every light mix element individually. Tips?
For everyone interested, we found a quick fix for the problem. In your render setup box, go to the Light Mix page and highlight all lights in your scene. You can then uncheck the enable box in the bottom left corner of the box. However, once you disable the lights, you can no longer adjust them as your work unless you enable them once more. This is the only solution we have found currently that allows for everything to be set up correctly while batch rendering what you need without rendering the light mix setup.
