Light Mix saved darker than what is actually rendered
SO after adjusting lights in light mix and im satisfied about it ,i save the image and it very dark ,i tried to change the Exposure but it isn’t the problem still getting the dark imaged ..I’ve tried to change the Gamma or override with different numbers while saving .. didn’t work also
IM NOT GETTING THE SAME IMAGE IM SEEING IN THE LIGHT MIX ..
What version of Corona, which host software, which version of the host software, which OS (if it happens to be C4D, on a Mac), what was the workflow for saving, to be sure you are in fact saving the LightMix and not the Beauty, and what format did you save to? Plus a screengrab of how it looks in the VFB in LightMix could be handy too. Thanks!
Im using 3dmax 2020 and Corona 4…and yes im sure im saving the light mix not the beauty..because im saving many other layers too..and im saving it as JPG..
What’s the workflow for saving? Save All from the VFB, or an automatic save through 3ds Max?
Tom G thanks alot for trying to help me ..i figured out why it was happening..that was because the render elements im saving were not having the same Gamma ,any way thanks alot
You are welcome, and glad you resolved it! :smiley:
