Light problem
Hi i have question i hope anyone knows this. With old vray 1.05 how can i edit all lights at once? Because i have room with spot light or rectangle light but if I don’t like to level of the light I have to do this individually which is very difficult is there any other way to do that?
Thanks.
Re: Light problem
so including mod’s no one knows how to do this right?
Re: Light problem
There no way to edit the lights at once. When I work with light I add a small line to the light and create a component between the small line and the light, then I copy the light component in my desired place. For example If I copy the light component in 10 different place, when I edit one light all the other light change too. But if you already place the light in their position, there nothing that you can do to edit all the light at once.
Re: Light problem
great technique, i never tried that, everyday i learn something new here
Re: Light problem
Thats call sharing guys :slight_smile: thanks for information
Re: Light problem
mens gucci shoes/louis vuitton speedy 35/louis vuitton speedy bag
