Heya
I have a bit of an issue. I have HDRI + Sun in my scene. I set up my render elements to give me both light from sun and HDRI. However both of them have specular pass included in it. Is there a way that we can have an extra pass that would give us allso specular for each light select? So then I can control specular for each pass of light. Atm I only have the general specular which controll all…
Or does ano1 know any other way of doing it?
Need 2x light diffuse pass + 2x specular pass.
Thanks.
Tbh only turning on individual lights will do it at the minute. You could also try giving everything a black material and keeping it’s spec, but turning off diffuse and reflections for the light? The light select would hopefully give you a black pass with only spec then?
U saying to clone my sun and hdri. Disable diffuse/reflection cast. Leave just specular cast. Get 2x more select light filters on render passes for each of these lights and I have the specular and diffuse for each light for comping - destroying beauty render - but I dont care abou that. Or disable specular for the oryginal lights and then use extra clones with specular only and I can keep beauty pass nice. Wohoo !
Great idea mate ! Why didnt I think of that before
The only problem is if I have 20 lights I need to do another 20 passes for each specular which is quite time consuming so yea +1 to my wish list !
Need separated specular !
Thanks, bye.
