Hi.
I want to use light select elements by mesh lights or light material.
Is it possible?
Hi.
Is it possible?
Support for V-Ray Light material by the Light select render element is in our “to do” list.
Mesh lights should work fine with Light select render element. What build you are using?
Thanks to reply!
I try Light select render element by mesh lights again.
It’s OK!
By connect vrayLightMeshProperties_Link to lightselect node, it’s fine.
Yes, this is the correct approach and should work well.
Hi did anything change in this topic? I bumped to this problem and light materials still doesn’t work with light select element ![]()
You can now select materials with non-black Self_illumination or Light Material for the selected Light Select element.
Ouch I didn’t notice this thread is for Maya
In Max its not possible or I don’t know how to do it.
