Light Select Save with Preset
Is there a workaround to get the light select render element to remember the lights that were selected when loading a preset? Even if I do not rename anything, when I load a preset with light select in it it just shows any previous lights as <deleted>.
I’m not sure if we can make it work but I’ll add a note to look at it.
Same problem, did you fix it or made a solution for this ?
We added the option to select lights by layer for exactly this case. Using the include/exclude lists will not work.
Thank you so much that’s work better now ^^
