light streaks / bug?
light streaks under the window… is this bug or caustics?
Is the material glossy? Try disabling glossiness/bump. I don’t know where the light is coming from, but it is possible it is just some reflected light. I would need to see the scene to be sure
a sun and several corona lights…
with white material, no light streak, send the scene via Renderer for architectural visualization - Corona | Chaos
Maybe it’s “Crazy Bump” (bump >>>1)?
ok, I went over the scene, and it seems like it is caused by a combination of factors:
  • extreme bump value (44)
  • extremely low bump filtering value (0.01)
  • using reflection further increases bump strength
  • using very skinny triangles causes self-intersections
I won’t fix this now, but I’ll save the critical part of the scene (the 2 offending polygons) for later, when I’ll try to deal with selfintersections in more general way
