Light view, texture export?
I need a light analysis in plan view, for an apartment, to see how the rooms are lit. Exactly what Light view does, but in plan view.
Is it possible? Somehow to bake the light analysis maybe, and then to see it from top view?
Here’s an example:
Thank you!
@FloatingVolume Thanks for your suggestion. I filed your request.
Seems to be a good addition to the light view in 3D but we have to check the feasibility.
An other solution could be if clipping planes could be used, but under the unclipped light conditions.
Yes, @Micha ! Clipping planes that don’t affect light would be a great addition. Especially when rendering interiors and building sections.
@Jonathan_Knoefel , thanks!
Another suggestion would be to have two light studies: one that shows the radiation and another that shows direct sunlight.
The clipping planes in SU don’t affect the light (I wish they would sometimes)
I wished it would work at Rhino so too. @Jonathan_Knoefel Is there a chance? It would help a lot, for example I missed it at my last project.
@Micha What exactly do you wish for Rhino?
It could be great if the clipping plane would work. And it would be very useful, if the lighting could be kept like without clipping plane enabled. For example I have an interior and I would like to look inside without to get the daylight trough the clipped geometry.
@Jonathan_Knoefel What do you think, are this kind of advanced clipping planes for EfR possible?
@Micha EfR = Enscape for Rhino/Revit? :wink:
The support of clipping planes is on our agenda.
@Jonathan_Knoefel For Rhino please. My hope is if it works for SU it could be quite easy added for Rhino too.
@Micha The API’s differ a lot, so it’s not that easy to adapt for all platforms.
I come back to this topic with another example.
What you see below is a solar analysis diagram showing the amount of heat on a façade. North side is more cool (blue), couth side is hot(red)
The radiation is calculated for 1 year in Wh/m2 using ladybug in grasshopper.
This is useful when designing shading elements for buildings, adjusting their depth etc.
