This is what my lighting set up looks like…Maybe since the lobby is so exposed I don’t need Sky Portals?
I wouldn’t bother with sky portals - it’s pushing too much light in and the shadows on the first are much better defined. If you want more light in then increase the power of whatever is in the environment (is it a hdri or sun/sky?)
Where you have a bunch of IES lights at the very top though, try adding a big vray plane up there with a warmer color to counter balance all the cold coming in from the environment. It’ll create some contrast with the lower areas being colder and the top a little warmer. Or just turn up/warm up the ies lights you already have.
Might be easier to do all this with a mid grey override - I find it’s easier to see whats going with colors in the lighting when doing big changes.
Thanks Neilg!!!
I got rid of the Sky Portals and added some low intensity warm plane lights at each floor lever in the stairway, and wow did it make a difference! I’m using a Vray sun and sky so I can probably boost it a little bit.
I have always have used plain white lights and now see where the warmer ones help. ![]()
