Hello Everyone
I set my scene and saved the view. (Enscape Revit)
I saved and closed the file. Next time I start enscape with same view, my exterior lighting and shadows have been changed
Can Someone advise how to fix it please?
Thank you
Hello Everyone
Thank you
Use the saved view in Revit to drive Enscape. Open the view management tab and select the view that you saved from Revit.
Or make the view active that you saved from Enscape and then start Enscape.
https://www.linkedin.com/pulse/creating-solar-studies-revit-enscape-phil-read/
Hello Phil
I really appreciate your time and advise ![]()
This works!
Thousand thanks
