Lighting in rendered image different from preview
Hi
I’m having an issue with balancing lights. See the images below
In the real time Enscape window it looks like this, a nice warm glow from the building in the evening light:
But when I render the image out, it looks like this. Really dull.
What am I doing wrong here? Latest Enscape version 3.5 install, Sketchup Pro 2022. Any swift help appreciated, I’m trying to hit a deadline. I don’t want to have to photoshop it but that might be the only option at the moment!
@BarryFishFinger , just to make sure, did you only start to experience this recently after updating to 3.5, or was this an ongoing behavior in your scene even with 3.4.4 and such before the whole time? I reckon you’re not adjusting the Rendering Quality or anything else before taking the rendering?
I’ll also try to reproduce this locally myself, if there is any chance for you to briefly share the scene then you can gladly do so as well.
@BarryFishFinger , another question, even though it’s likely trivial just to make very sure, you’re also not using any different time of day saved in the view which is being rendered, nor a different skybox or anything of the likes?
If so then I think receiving the scene would actually be most helpful here.
Hi Demian, thanks for the response.
How would you like the scene sent over and I’ll see what I can do.
Same time of day for the view being viewed/rendered, skybox is Enscape default and render quality is on Ultra. I’m not sure if this behaviour occurred pre 3.5 or not unfortunately, first time doing an evening scene!
In this case you can simply use wetransfer.com and send me the link to the file via a direct message. Thank you!
Hello, may ask what the fix to this was? I am having the same issue, the lighting in the rendered image is majorly lacking in spread.
This is the preview:
This is the rendered image:
I am using enscape 3.4.3, in Rhino 7, and there is a mix of rhino lights and enscape self-illuminated materials.
