HI all;
I just tried Enscape in VR for the first time. I noticed that when switching to VR mode, the lighting on my ceiling changes… any idea why that would be?
Screenshot 1 - Enscape w/o VR enabled.
Screenshot 2 - Enscape with VR enabled.
Hi @marckleinmann_1 ,
this is very likely to be due to the current ‘Rendering Quality’ setting which you can adjust in our ‘General’ settings window.
You can improve the lighting quality by setting the ‘Rendering Quality’ slider to a higher value, but keep in mind that this will stress your hardware more.
In general, VR display requires a very carefully adjusted quality, as it has to display far more frames per second than regular monitor display. However, provided you’re using matching hardware, you should be able to receive very much comparable if not identical results as non-VR mode by setting Rendering Quality to ‘High’ or ‘Ultra’.
Please let me know in case this doesn’t resolve the issue.
That did the trick. I had to push rendering quality all the way up to get matching lighting.
Danke schoen.
M
