Hi guys. So my panorama render has these lighting stripes that divide the room into different portions.
This was created with Enscape 3.0. Auto exposure, auto focus, bloom are all off. Rendering quality is set in ultra and panorama resolution is high.
Any solution for this issue yet?
@Livie1310 , as mentioned to you in the other thread, I’m afraid this is still an ongoing behaviour caused by the way we stitch together panoramas to render the final results. You can of course dial down the Rendering Quality to Draft which should help with actually completely eliminating this behaviour. But, be aware that the render quality may be a bit worse, give a shot if you like though.
Also, just to make sure, does this behaviour change whatsoever if you decrease the panorama resolution to Normal?
