Can you help? I’ve placed IES Lighting into my scene and i’m getting some strange shadows from the lights on the walls. Any ideas? I have moved the position of the lights and it disappears for a few seconds but then reappears when i render.
its very annoying to move one by one my lights since they are alot make a square patern in every room ? so painfull. I rendered panoramic so when the result is done i saw square patern in every locations since my room door is always open ? i dont think so the door must close ? is there anothers solutions that i dunno… ?
you can see my sketchup 2018 view and my render window with high (unchecked automatic resolution) set in preview and (set my setting to ultra render quality image) and also other light bug you can see my yellow line light with long size and the result in the render window.
2.5.2 still happen. Need to move a little bit light object up or down left or right and back to normal. Sometimes move render quality down too, sometimes move the atmosfeer slider left or right make it normal too. And also restart Enscape, bug is gone. But when we move our position to other place my house object it will happen again so i need re-restart again..
and as you see in that picture when i rendering it in panorama it happen again but when in realtime preview before there is ok no bug, after rendering end, the realtime preview will show this bug so i need to move light object and bug gone again. Repeat rendering.. if i lucky the bug wint show.. but if no lucky i’ll try again move the light and so on.. ans so on.. until rendering dont have this bug ???
wait.. i found simple solution.. no need to move, no need restart, wow amazing, just select one of this light object and move the slider of Luminous Light to the right or left just one or two point no problem, and walaaaaaa.. all the square patern bug gone in all place i’ll try for 2.6 later ? i’m very curious for realism at 2.6 when read the blog article
and also if my solution above unsuccesfull try this click cast shadows on and off and you can turn it on again, but it is need to select one by one light object. The bug will gone too..
