Lighting issue
Hi all,
I have a problem where as I’m having to set light multiplier in the thousands for each light, currently have a light material set to 50,000 just to get it to show. Interior shop scene.
The scene did have a Vray sun and environment set but have now deleted this, I’ve even merged the whole scene into a fresh Max file, sam issue.
Many thanks for any help in advance.
elliot
Check what exposure your vraycamera is set to.
Also check if there are any exposures set under exposure control in environment.
Check that you dont have exposure override in your vfb
lastly Check that your system and display units are correct.
If none of that works, you’ll have to give us more info to work with, maybe some screenshots of your settings
Or you can just send us a stripped down version of your scene - and we’ll take a look what is going on.
