Lighting object shape error
Hey! The Light Rectangle has an error… It is being limited to a maximum of about 80cm of lighting. For example, if I create a 200x10cm rectangle, the lighting is only done in a space of 80x10cm… But then another problem arises, the larger the size the square light turns into a circle shape, for example, 200x200cm creates a 80x80cm circular lighting. That’s very strange! The problem also happens with the circle.
i have had to delete these and start over. they seem to do this when they are grouped? Sometimes I have to overlap the linear lights. either way its a bug in the software
