whats wrong with the lights…
it looks to me that default light is on.
erm… post your settings ![]()
you can have omni lights in scene dont have?
Are you using a hemisphere for the sky? Your trees don’t cast shadows. You can copy the plane by rotating 90 degree uncheck visible to camera and it’ll cast some decent shadows.
--Jon
im lost for words
i deleted all the lights and created an omni but turn it off and it still renders…as if there are lights…
Wouldn’t happen to be that the environment multiplier is too high? 4 seems pretty high, but then again I haven’t really played around with outdoor scenes.
-Matt
any self illuminated materials?
4 is definitively too high if your ambient light is this bright. You should probably keep it to 1/1.5 and use a direct light or an ies sun to give your scene a more outdoor feeling. Don’t forget to set the shadows of your ies sun as vray shadows/area shadows and your scene should definitely look more real.
also what are your colour mapping settings ?
Do you have some mirrored objects ??
newbie question:
Exacty what does the “default lighting” check/uncheck do on the VRAY GLOBAL SWITCHES ?
I saw one of the Natty tutorials, he unchecks that field (and so on this thread) i dont remember noticing a change on the render when i unchecked that.
Finally…
Thank you guys…the enviorement was to high(funny thing is it was ok before.)…didnt use any color mapping…no extra or mirrored objects…it was just 1 of those days…i reset my max file and merge all the object in without the lights…started doing the lights again and it was ok…i guess its just a corupted file…many thanks to all of you…any other comments?
By the way…to all those guys trying to eliminate white, red, green patches…easiest thing to do is either change all the metal shade to blinn.
And just use vray materials. using vray shaders are faster than max default. proven. final resort is to use photometric light with ies files…
hey reza ![]()
the problem part in the first image you sent reminds me of the big hotel in Dubai which looks like a sail-interesting ![]()
Max will automatically render using a default light if no other lights are present in the scene. Even if you have the environment on in the vray settings, max will still render the default light. I’m assuming by unchecking this box it will stop Max from rendering this light. One other way to stop max from rendering default lighting without adding any light to the scene is to add an omni light and set it to ‘off’
-Matt
curious
well the building you see here belongs to the Malaysian goverment…in Sabah. i guess the reflection does look like a sail…i think youre refering to the hotel in dubai
