Lighting set up interior
I have mostly used enscape for exteriors. I am experimenting with some interiors, and I have a cove area for a light. Without the light the area is very bright, which in real life supposed to be dark before I place the light. Any way to adjust this?
Thanks!
Best you post an image.
Cove lighting is a mystic art form that only a few practitioners have learned.
There is a feature request to make it simpler/easy/obvious, but until then there are many things that can direct you towards the effect you are looking for - it depends on the specific application (as Micha says; show the image for targeted advice).
