I’m linking Revit files. When I render I get no light. I have to add max lights such as an Omni light to each revit light for lighting to work
Is there a way of converting the Revit photometric lights so they can be used with Corona
We are talking about Corona for Max, right?
What kind of objects are the Revit lights once you open the scene in 3ds Max?
I am not aware of any converter like this, but if you could find a converter that converts those Revit lights into 3ds Max lights, then it should help. If you could convert them to Vray lights, then Corona Converter could convert them to Corona lights.
Thanks for your response. The lights are 3ds Max Photometric lights
They should work with Corona, if you set the shadow parameter to Corona.
Hope it helps
Unfortunitley they don’t work with corona. Even if I change the shadows to corona shadows
I have worked out a work around
