i have a interior scene that renders fine with lightmaps subdivisions set to 200.
lightmap calculation is done in 5 minutes.
when i raise the subdivisions to 300 the calculation time increases unproportional. after 20 minutes the calculation is still not finished (maybe it hangs). have tested a few time with the same result.
with the default value of 1000 subdivisions i see no progress at all.
what im doing wrong?
sorry but i can not give away the scene.
first bounce is set to irradiance map, second bounce to lightmap.
i use the medium settings for the irradiance map.
vray 1.46.04
I’m noticing numerous speed/scene related issues with lightmaps and the new build, it’s hard to pin down at this stage but it doesn’t seem to be memory related. Scenes hanging on 100% CPU utilization (small scenes) network problems, slaves crashing, problems with Xref’s, misc max crashes…
Just for experimenting Long John, I know that Vlado has already fixed it, you may want to try a few things. First try putting a VrayWrapper on all your standard materials, second, try changing all your materials to Vray Materials.
Hi, i was experimenting those problems wint one of my scenes, and interior, then after some test i find that if i hide the objects with vray materias who has opacity it doesnt hags, so i change those mateials withe the blen option, i was having some serios troubles with it, aparently the opacity option on the vray mateirl doesnt work to well with lightmap. if you find something elese or maybe more accurate let me know..
ps: sorry my english is terrible, my native is spanish.
